MW live hyd question
Posted by Stroked550 on January 04, 2005 at 12:48:51 from (209.221.24.123):
Anyone know the specs. of the pumps used on the M&W live hyd. kits for a Farmall M (pressure/flow rate)? The belly pump was used as the tank and the suction port is only 1/2"- the port on the pump is 3/4. I'm building a new tank to take place of the belly pump. It will fit into the same opening and stick out 5" (about the same as the bottom of the belly pump). Tank will hold 3.5 gal. Any suggestions/comments?
Thanks
Ben
Post a Followup
Subject:
