Re: 706 Cutting Out
Posted by andy R on January 06, 2005 at 21:54:14 from (69.66.64.206):
In Reply to: Re: 706 Cutting Out posted by dvtw on January 06, 2005 at 08:41:25:
My 706 gas does the same thing. Like you, I need to pull the choke or slow the engine. Nearly all of the time it is gunk plugging up the little passageway in the sediment bulb base. Surprising what tapping on the potmetal housing of the sediment bulb will do for a short-term fix. Generally I had to take off the bulb and probe a little wire up into the holes. Once in a while I have to twist out the shut off and probe that hole too. If the gas starts running strong you know you got the restriction. I think this problem occurs more often when the gas tank is nearly empty. A full tank probably provides a little more pressure to help pass the gunk through. Seems like the stuff that was plugging it was like thick slime. Sometimes you could see it coming out when cleaning it. To completely eliminate the problem I cut some fine fine brass screen and wrapped the fuel inlet on the sediment bulb and tied it with fine wire. I took a hacksaw blade and cut a notch around the sediment bulb inlet pipe for the wire to snug into. This helps hole the wire and screen on. The circled screen is a smaller diameter than the hole in the tank therefore it could be inserted back into the tank. I think some sediment bulbs have this feature. Goodluck.
- Update Farmall Don 09:02:32 01/07/05
(0)
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
