Re: 784 manifold
Posted by JB2 on January 07, 2005 at 19:35:00 from (66.185.85.75):
In Reply to: 784 manifold posted by TL on January 07, 2005 at 16:29:44:
Hi TL, broke one on 454D where threaded exhaust pipe goes into manifold many years ago. Took it to local welding shop and had it welded. Still holding today.
Hydro84 and 884 should have same manifold and possibly 684.
Good luck
JB2
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
