Just thought of something ....
Posted by fixitforfree on January 08, 2005 at 06:59:02 from (4.227.120.18):
In Reply to: Re: Hydraulic (pwr. steering) problem - will this posted by Gerald J. on January 07, 2005 at 20:28:17:
I bet the priority flow valve on a 444 is located in the valving under the steering column isn't it? In other words, the priority flow valve is part of a much more complex arrangement on the 444 so simply getting one off a salvage 444 won't work will it? My 364 has none of that valving under the steering column like many tractors do.I wonder if a simple, adjustable priority flow valve can be purchased for a reasonable price through a hyd. supplier? Have you ever seen one?
Post a Followup
Subject:
