Re: Stuck Cranking Shaft on Farmall H M
Posted by Wayne Swenson on January 08, 2005 at 19:13:12 from (66.191.70.4):
In Reply to: Stuck Cranking Shaft on Farmall H M posted by Wayne M. Smith on January 08, 2005 at 17:57:06:
Is the small shaft or the large pipe stuck or both?
1. Try tapping on the end with a hammer, try turning the big end with a pipe wrench, or get the flame wrench out & heat things up a bit.
2. You could jack the front end up & remove the wheels to gain access to the crank area (CAUTION! Block things securely to prevent an accident when working under the front end!!)
3. Take the bolster off & turn it over so you can see what you are doing and not having to work under the tractor.
It took several years to rust in place so take your time to loosen it up.
Good luck. Keep us posted on your progress.
Post a Followup
Subject:
