Re: Cost to overhaul 666
Posted by Heat Houser on January 08, 2005 at 20:16:15 from (69.66.106.177):
In Reply to: Re: Cost to overhaul 666 posted by K.B.-826 on January 08, 2005 at 19:25:01:
Adjust the valve clearance after 50 hours and then yearly and forget the low ash oil. The neighbors 560 would need a valve job every year and I adjusted ours and never did a valve job.
Post a Followup
Subject:
