Re: F-20-rebuild magneto
Posted by Nebraska Cowman on January 09, 2005 at 03:48:57 from (65.162.146.104):
In Reply to: F-20-rebuild magneto posted by Bill Friedrich on January 08, 2005 at 19:21:16:
Ummm... ya, I can try to walk you through it. I assume you have the F4 IH magneto? The impulse coupling must come off to get the armature out. It is keyed on a tapered shaft. take the nut off and use a puller. Sometimes a little heat helps. Take the screws out of the clip on top and gently remove the magnet. put the magnet on a piece of steel as a keeper while you are working. everything else is pretty self explanitory.
Post a Followup
Subject:
