Re: More crank bearings
Posted by brtx on January 12, 2005 at 16:09:31 from (65.68.183.163):
In Reply to: Re: More crank bearings posted by CNKS on January 12, 2005 at 14:47:03:
cnks plastigauge has to be used on a dry surface because you are measuring clearance for oil flow.any oil on the surfaces will give you a false reading.lubricating bearings on assembly can be done with a pressure tank filled with oil.connect a hose to the oil galley then put air to the tank.this will lube all aspectsof the oil system.never run your tank empty and you can fill your oil pan at the same time.when you are reafy to start remove the coil wire and let the engine free wheel till toue have oil pressure on the gauge.ready to fire then.my 2 cents
Post a Followup
Subject:
