Re: More crank bearings
Posted by CNKS on January 12, 2005 at 14:47:03 from (204.249.178.138):
In Reply to: Re: More crank bearings posted by lee on January 12, 2005 at 13:39:54:
At least you said plastigage dissolves in oil. The machinist said he doesn't do any assembly, assuming he does good work (probably does as the tractor dealers send their work to him), I still need to know how to use the plastigage properly, which I believe I do now. As I asked below, if done dry, the dry measurement on the paper scale must compensate for the lack of oil in the in the upper journal, since the crank is should bottom in that journal because of no oil, doubling the clearance. All this is immaterial, since I'm not doing the grinding, as long as I correctly measure the clearance with the plastigage -- thanks!
Post a Followup
Subject:
