Re: Super H wont start, electral prob.
Posted by jonnny2006 on March 10, 2009 at 16:07:29 from (67.142.130.26):
In Reply to: Super H wont start, electral prob. posted by jonnny2006 on March 10, 2009 at 15:43:04:
Also i shoud add that when it was working normally every time i would turn the ignition switch on the amp meter would always show a 10 amp discharge. It might not actually be 10 amps as it is a 12v conversion. Even if i take the fuse out and turn the ignition switch on it still shows that 10 amp draw. I will Try a jumper wire and see if she will throw a good blue spark. It does turn over real good so the battery has plenty of juice. All the other tractors i worked on had the 6 volt gene or a mag. thanks john
