Re: 3 Super C Questions
Posted by FC on January 13, 2005 at 20:35:54 from (66.49.43.10):
In Reply to: 3 Super C Questions posted by terryj on January 13, 2005 at 20:06:32:
I can't answer any of your other questions, but the hydraulics normally work pretty well even when cold. It uses a lightweight hytran fluid that seems to flow well at low temps. Or at least this has been my experience with my C. I know some folks have put 30 wt. motor oil in them and that would cause some sluggishness when cold. If so I think I would change it to the hy-tran, and your hydraulics should go right to work as soon as it starts unless you have extreme temps.
Post a Followup
Subject:
