Re: 3 Super C Questions
Posted by TDK on January 13, 2005 at 22:27:12 from (205.188.117.13):
In Reply to: 3 Super C Questions posted by terryj on January 13, 2005 at 20:06:32:
1) If you have the rear light with the saftey red bulb inside you will have a two-position switch that twists. Knob will be a knurled metal or plastic one.
2) The 12 volts will burn the points up. It's debatable as to how long it'll take, but I did this on a car years ago and it only took about 20 minutes.Mount a resistor near the coil, attach wire that runs from switch - coil to one side of resistor. Make another wire to fasten on other post of resistor and to coil. You'll have to do this eventually anyway, if using 12 volts, may as well do it now. Resistor cost between 5 - 7 dollars.
3) You shouldn't have any trouble with the hyd. in cold weather. Use IH Hy-Tran ONLY!
Post a Followup
Subject:
