Re: tachometer drive replacement
Posted by brtx on January 14, 2005 at 00:13:42 from (65.68.183.163):
In Reply to: tachometer drive replacement posted by L.B. Novice on January 13, 2005 at 22:22:43:
parts book shows only one drive so yours should work.remove the nut holding the cable. then remove thehousing which holds the gear assembly in.with the housing out remove the assy gently.should be a broken shaft on the pencil gear.willprobably need a pair of needle nose pliers.i would count the teeth on both gears and measure the shaft diameter.while you hve that out i would recommend putting some grease on the tach cable andtrying to spin to make sure it turns freely and that the tack works.good luck
Post a Followup
Subject:
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
