Re: M wide front end Questions
Posted by Dick Davis on January 14, 2005 at 09:12:07 from (64.12.117.13):
In Reply to: Re: M wide front end Questions posted by Allan in NE on January 14, 2005 at 09:01:17:
Allan, I'm learning something here. I have one without the plate installed and the WFE is forward. You say the plate stays installed and you can move the WFE forward? So does the plate allow a further forward movement than direct attachment? I was always told the plate was for moving the WFE back and not used for extension. Not the first time I was misinformed. Thanks for any additional info. Dick Davis
Post a Followup
Subject:
