Re: One Way Cylinders
Posted by brtx on January 15, 2005 at 13:42:04 from (65.68.183.163):
In Reply to: Re: One Way Cylinders posted by Jimmy King on January 15, 2005 at 10:05:29:
we had a 47 or 48 farmall with mounted cultivators. on top of the rear axle on both sides of the seat there was a lever to set the height ofthe front cultivators.the rear raised with the front by a rod connecting to the front. if my crs memory is right we removed the draw bar when mounting the cultivator.i believe it was lifted by the lift all.the liftall also raised and lowered the mower that bolted onto the draw bar
Post a Followup
Subject:
