Re: wandering 300 Farmall
Posted by hammerheadd on January 15, 2005 at 18:50:48 from (152.163.101.13):
In Reply to: Re: wandering 300 Farmall posted by Gordo on January 15, 2005 at 07:47:22:
When I rebushed the center support on the 300 I measured the shaft size and the hole in the center support then went to the hardware store and bought bronze bushing to fit then drilled a hole in the bushing to line up with the grease fitting so it could be lubed and pressed it into the support. If memory serves me correctly the bushing measured 1 inch outside and 7/8 inch inside diameter. hope this helps
Post a Followup
Subject:
