Re: Wrong Head, pistons or rods???
Posted by Dixieland on January 17, 2005 at 13:18:47 from (64.91.26.64):
In Reply to: Re: Wrong Head, pistons or rods??? posted by Andy Martin on January 17, 2005 at 10:50:15:
Just pulled the head back off and found the # 4 piston does come above the block. How do I determine the correct pistion or rod to correct this
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
