Re: TD-9
Posted by Ron in Nebr on January 17, 2005 at 16:48:03 from (65.172.143.217):
In Reply to: Re: TD-9 posted by Geoff NY on January 17, 2005 at 15:13:28:
Geoff, it is possible he DOES have his information correct, since, as I'm sure you are aware, the Diesel versions did indeed have a small gasoline tank that had a water separator/sediment bowl underneath it that they used for starting.
I think that in a pinch a standard sediment bowl off of any gas tractor could be used, although the stock one had a shorter glass bowl under it.
  • Re: TD-9 TD-9 Mark 16:30:12 01/18/05 (0)
Post a Followup
Subject:
