Re: farmall I-6
Posted by DAVE HESS on January 17, 2005 at 18:01:04 from (208.32.94.25):
In Reply to: Re: farmall I-6 posted by Harold H on January 17, 2005 at 11:53:25:
THANK YOU HAROLD. IT IS AN INTERNATIONAL AS U SAY
(ALL I HAD TO DO IS LOOK AT HOOD AND SN,)
I AM TOLD BECAUSE IT IS I SERIES 6, IT HAS AN EIGHTH INCH OVERBORE STD. MAKING IT A 264 CI
IT HAS LESS THAN 50 HOURS ON AN IN FRAME OH
SLEEVES PISTONS RINGS CONN BRG, VALVE JOB.
SOUNDS REAL SWEET. POWER OUT THE WAZOO.
THIS GOOD AS IT WILL BE REQUIRED TO WORK FOR ITS KEEP. I WILL START IN THE SPRING WITH HYDRAULICS
MOUNTED ON THE FRONT. MUCH TO LEARN, JUST GOT HER YESTERDAY. THX AGAIN
Post a Followup
Subject:
