Re: corn stoves
Posted by Andy Martin on January 19, 2005 at 07:19:53 from (64.219.39.195):
In Reply to: Re: corn stoves posted by rebuilder on January 19, 2005 at 06:22:25:
Don't get me wrong, I wasn't trying to make fun of corn stoves. I just thought it would not be a good idea to try to burn popcorn in one.
I've been trying to figure out how to burn square bales and/or old tires for heat. There is a lot of energy in either one and they are cheap to come by. Either one takes forced draft to burn clean and avoid smoke but should probably be outside the house.
If you grow corn the corn stove is even a greater idea, especially if you can use some damaged grain. I can't imagine much of anything like mold causing a big problem, except maybe trying to burn popcorn : )
Post a Followup
Subject:
