Re: OT 10 ply trailor tires
Posted by lee on January 20, 2005 at 19:34:03 from (24.24.95.246):
In Reply to: OT 10 ply trailor tires posted by Buddy Woodson on January 20, 2005 at 18:49:13:
As long as you get the proper load rating you can run a radial or bias ply tire. There are advantages and disadvantages touted for each.
Some say for heavy transport tires a bias ply with proper load rating will handle better due to stiffer side wall vs a similar load rated radial. A radial is probably more expensive than a bias ply of same rating. The ply rating often times doesn't correspond directly to the actual number of plies used in the construction of the tire.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: 65534p> :
