Re: Possible to use a Case 580CK hoe on an H?
Posted by old on January 21, 2005 at 11:15:52 from (207.69.137.35):
In Reply to: Possible to use a Case 580CK hoe on an H? posted by Dave in CT on January 21, 2005 at 09:11:19:
It would probably have the power to run the hyds. but probably not the weight. Unless you have a loader and even then you would need some weights up front or all it would do was stand up on its butt so to speak. The backhoes on those where and are very heavy, I know I have a 580B sitting out in the yard with the reast of my toys
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: 65534p> :
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
