Re: Possible to use a Case 580CK hoe on an H?
Posted by captaink on January 21, 2005 at 11:27:31 from (66.115.214.56):
In Reply to: Possible to use a Case 580CK hoe on an H? posted by Dave in CT on January 21, 2005 at 09:11:19:
Just trying to help here a bit, I have a CK680 hoe complete with loader and I’m not sure how much smaller the CK580 is. I’m not sure if you will even have enough power to run the hydraulics as the factory engine on mine will pull down a bit when I’m working it hard. Weight is definitely an issue, as even with the heavy industrial loader on it I can pick the front end up when digging with the hoe. That being said, you can put the hoe one the H and get it to function, but…I really wonder if you will be happy with the results though. My 2 cents…
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: 65534p> :
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
