Re: Possible to use a Case 580CK hoe on an H?
Posted by Hugh MacKay on January 21, 2005 at 17:02:32 from (216.208.58.110):
In Reply to: Re: Possible to use a Case 580CK hoe on an H? posted by Dave in CT on January 21, 2005 at 16:38:23:
Dave: You and indeed Allan have more faith than I. That old 580 Construction King tractor was quite a solid hunk of steel. I far as I'm concerned, about the only engineering that ever went into Farmalls for loader use was customer demand.
That same customer demand destroyed the very best draft tractor North America has ever known. Sure a Farmall didn't shift gears very well, but put them on a plow, disk or cultivator and often times you were in the same gear 9 pm as when you started at 5 am, and you hadn't been in any other gears all day. They had the torque to pull you over that hill, through that hard spot and do it all day, day in and day out. Up to the end of letter series they weren't even engineered for the added weight of mounted implements
My point is, there are more economical ways to do this. Heck, build a powered trailer out of a 5 ton truck chassis, mount your hoe on back of that. Five min. uncoupling pto and draw pin, and you can use the H anywhere, and for anything else.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: 65534p> :
