Re: 986 TA fixed itself
Posted by RickB on January 22, 2005 at 09:31:52 from (205.231.145.136):
In Reply to: 986 TA fixed itself posted by Mapleridge on January 22, 2005 at 06:13:13:
An IH mechanic with over 30 years experience on hydraulic TA's taught me that if one slips in TA mode the sprag is failing or failed. No exceptions. It will not cure itself. It may drive on the low side clutchpack, but it won't pull hard for long. You can check hyd flow and pressure, dump valve spool adjustment and all the rest, but your sprag and therefore your TA is toast. Slipping in high can be a hydraulic problem, but not in TA mode.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
