Re: 986 TA fixed itself
Posted by JJK on January 22, 2005 at 13:58:17 from (216.189.131.9):
In Reply to: 986 TA fixed itself posted by Mapleridge on January 22, 2005 at 06:13:13:
If you decide to replace your TA, go with the diode TA. It provides a more solid lock up than the sprag style TA and the warranty is pretty good if somthing was to fail. We usually replace the constant mesh gear with the TA(trying to prevent gear noise). Remember to check your shift forks, quill gear, splines on the pressure plate, pto drive gear, bearing cage for pto drive gear(bearing spinning in cage), MCV pump, the spools in the MCV(check for scoring), related parts in speed shift cover, and the length of the spacers on the countershaft. These are some of the parts that I"ve run across that wear or brake. Also take a close look at the pto driven gear, look to see that the teeth have an arch on both sides, if one side is like a ski slope, this will make for a lot of gear noise or premature wear when putting in a new pto drive gear. If your clutch linkage is bolted to the bellhousing this is the time to update it to the bracket that bolts to the cab. Check the cab mounts. If the cab mounts are bad I"ve replaced them with the Case-IH Magnum cab mounts(better mount). This fixes a jumpy clutch problems. Checking all these things will usually prevent foul language and from you having to go back in a second time.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
