Re: C Runs 2 seconds then dies UPDATE
Posted by Ed Topel on January 22, 2005 at 20:09:21 from (152.163.101.13):
In Reply to: Re: C Runs 2 seconds then dies UPDATE posted by railroadgoat on January 22, 2005 at 15:42:05:
You may not even need a kit. It sounds like you have a pluged-up main jet since you have gone through everything else. Pull it apart being carefull with the bowl gasket and remove the main jet. It's probably got crud blocking it.Clean everything out and blow out the passages and reassemble. If you need to you can cut out a new bowl gasket. Good luck, Ed
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
