Re: TA Design
Posted by K.B.-826 on January 23, 2005 at 18:56:34 from (209.163.30.68):
In Reply to: TA Design posted by PAULIH300 on January 23, 2005 at 10:43:13:
Here's how the TA works- The Mechanical TA used in the smaller IH's is a planetary unit. It is made up of an input shaft, a 7" clutch, a planetary carrier, the planetary unit, the overrunning clutch- known as the ramp and rollers, and the output shaft. Power enters the unit through the input shaft from the engine clutch. When the lever is ahead, (DD), the 7" TA clutch locks the input shaft to the planetary carrier, and the whole assembly rotates as a unit, resulting in no reduction of speed. When the lever is pulled back, the TA clutch disengages, allowing the power from the input shaft to enter the primary sun gear in the center of the planetary unit. The primary sun gear turns the primary planet gears, which are attached to the secondary planet gears, which turn the secondary sun gear, which is splined to the output shaft, resulting in the gear reduction. If the planetary carrier wasn't held still with the lever back, it would just freewheel around the sun gears, and the tractor would not move. This is why the overrunning (one-way) clutch, or ramp and rollers, is used. It is located between the output shaft and the planet carrier, and locks up whenever the planet carrier tries to turn faster than the output shaft. If it goes bad, the planet carrier will just freewheel. One more thing about the ramp and rollers- since it is a one-way clutch, it will lock up whenever the planet carrier tries to turn faster than the output shaft. However, if the output shaft tries to turn faster than the input (traveling downhill in TA) the ramp and rollers will overrun, causing the tractor to freewheel right down the hill. That is why you never go downhill in TA. To answer your question- The ramp and rollers do not need to ratchet (overrun), but it was the only way avalible in 1954 to hold the carrier still. Hydraulic clutch and brake packs and the seals needed to make them work realiable enough for farm equipment hadn't been developed yet. The ramp and rollers provided a low-tech way to automaticly hold the carrier still, but the disatvantage was that it would overrun if the output shaft tries to turn faster than the input shaft. If you welded the ramp and rollers engaged, you would basically be welding the output shaft to the planet carrier.
Home
| Forums
Today's Featured Article -
Show Coverage: Argyle and Mt. Pleasant Labor Day Weekend Shows - by Cindy Ladage. The last fling before summer fades into fall and we get busy in the fields are the annual Labor Day tractor shows. Beginning on September 5th and running through the 7th, the Argyle Antique Gas and Engine Show is held at the Argyle State Park. Located in West Central Illinois, the pine forest was the setting for the opening of the 22nd show. This year we decided to try to sell a few tractor parts, literature and wrenches to offset my husband's buying sprees. Saturday
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
