Re: Leaky Steering on A
Posted by Andy Martin on January 24, 2005 at 15:09:32 from (64.219.39.195):
In Reply to: Leaky Steering on A posted by Sebi on January 24, 2005 at 14:27:14:
The easy solution is to fill the gear box with grease. Modern grease will adequately lubricate the gears, stay soft, and will not leak out or turn to oil under heat.
This is a common solution to the problem regardless of whether you replace bearings and seals.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
