Re: Leaky Steering on A
Posted by AlBie on January 25, 2005 at 03:49:49 from (63.234.160.37):
In Reply to: Re: Leaky Steering on A posted by Andy Martin on January 24, 2005 at 15:09:32:
Had a leak in the steering and a one half turn of the steering wheel before the tires turned on my Super A I ... Was informed that they all leak and to use grease as a solution. They did not come out of the factory leaking oil and does grease sling up lubricant to the top bearing. Also the shaft is no longer available. Well the shaft is available and a new seal will prohibit leaks and oil will *sling* to the bearing. AlBie
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
