Re: Rocker/shaft clearance.
Posted by lee on January 26, 2005 at 08:42:31 from (24.24.95.246):
In Reply to: Rocker/shaft clearance. posted by CNKS on January 26, 2005 at 06:59:27:
You are traveling the same path I did on my B.
Nearly every part was replaced or refurbished.
I was very happy with the end result. So was the guy who bought it from me years later. The rocker shafts were badly worn. Surprisingly, the rockers were not. I had to buy the new shafts from IH, something over $100. The machine shop dressed the tips of the rockers where they contact the valves but did not have to bush them. If yours need to be bushed, I think you may make out better at the shop. What did you pay to bush your rods? Should be similar or less per bushing even if they have to make the bushings. They may be willing to cut you a break given all the work you have provided them.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
