Re: hot dip galvanizing on rims?
Posted by Wardner on January 26, 2005 at 12:28:44 from (4.154.247.172):
In Reply to: hot dip galvanizing on rims? posted by RT (seTX) on January 26, 2005 at 09:46:59:
Galvanizing can be done with three methods.
Hot Dip
Electroplated
Molten spray
I have used all three methods and I believe that the rims were electroplated. This accounts for the low millage (thickness) and premature rusting. Hot dip usually leaves a crystalin pattern on thin parts. Molten spray leaves a profile suitable for painting. The color is uniform.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
