Re: Need head bolt torque for Farmall 560 LP
Posted by Farmall560LP on January 27, 2005 at 13:51:31 from (216.167.149.147):
In Reply to: Re: Need head bolt torque for Farmall 560 LP posted by ejr-IA. on January 27, 2005 at 12:49:01:
Many thanks for the information. I follow you on the torque and the valve clearance, but do not understand setting the top dead centers for cylinders one and six as I have not moved the distributor or turned the engine since removing the head. Can you explain?
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
