Re: wd6 Will not stop....injection pump
Posted by DWV on January 27, 2005 at 18:26:36 from (152.163.101.13):
In Reply to: wd6 Will not stop....injection pump posted by rik on January 27, 2005 at 08:31:57:
Someting does'nt sound right.If you move trip lever to gas side then turn switch off to mag. or coil with throttle lever off engine should die.
May be sticking foot in mouth here,but I don't
think engine would have enough compression to run on gas side even if diesel is still getting to cylinders if linkage is holding starting valves open.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
