wd6 Will not stop....injection pump
Posted by rik on January 27, 2005 at 08:31:57 from (142.165.47.152):
hello, anyone out there know why my wd6 will not stop. After switching to gas to cool the engine down and lifting the stop lever to shut down the ignition....it starts again in diesel mode. (the diesel throttle lever is in the minimum position and is adjusted correctly). I suspect a problem with the injection pump but I am not sure what part of the pump to look at. seals??? thanks
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
