Re: Transmission Lubricant
Posted by Bernard Reunking on January 28, 2005 at 14:33:55 from (69.66.88.162):
In Reply to: Re: Transmission Lubricant posted by TDK on January 22, 2005 at 20:48:56:
Hi thran is the only oil to be used in I H tractors with a ta. Because Hy thran Will pick up the water and hold it in suspendtion in the oil. If the fluid is milkie or by losinng the bottom drain plug and water drips out you waited to long to drain and put new hy Tran in. Water will set on the T A and rust and T A will fail. I was told this 24 years ago by a shop boss. I have one SUPER M TA for 24 years. Changed fluid every other year and never replaced the TA. Grain farmer and use it almost every day. The pto is independent and holds two qts. and should be changed also. Even if it is not used.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
