Re: 826D Is it normal??
Posted by Allan in NE on January 29, 2005 at 03:57:28 from (148.63.132.164):
In Reply to: 826D Is it normal?? posted by 826TN on January 28, 2005 at 17:54:41:
826,
The big boys tell me that this is "normal" and the reason they do this is because this engine was designed around a 15:1 compression ratio.
They tell me that the cure is to install the high compression (17:1) pistons and to make sure the valves and seats are up to standard specs (you can't grind the valves and seats on a German engine, as this will lower the ratio even more).
I, for one, just cannot get used to this little 'cold smoke' feature, so as soon as my 966 gets outta the shop, in this one goes. :>(
Always somptin',
Allan
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
