Re: Farmall moisture problem
Posted by brtx on January 29, 2005 at 20:02:28 from (65.68.183.163):
In Reply to: Farmall moisture problem posted by Andrew in ct on January 29, 2005 at 13:29:55:
what are your signs of water in the oil? have you been running the tractor in the past 3 days? what did your oil look when you changed it? if it is a internal water problem the first step is to pressure test the engine usig a pressure tester on the radiator. i would drain the oil again then pressure test it with the drain plug out of the oil pan.if you do get water coming out the drain then its time to remove the pan and see where the water is coming from. may not be a water leak as is atated in the other posts.but it is something you should keep an eye on.hope this isnt confusing.i would drain it only if i saw more evidence of water. also if you do pressure test you may find other leaks to repair,but i would try to keep the pressure on it for an hour or so.if you have no external leaks and the pressure drops you could be losing it at the pressure tester connection or a internal leak.hope this helps.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
