Re: Farmall moisture problem
Posted by El Toro on January 30, 2005 at 04:27:16 from (152.163.101.13):
In Reply to: Farmall moisture problem posted by Andrew in ct on January 29, 2005 at 13:29:55:
Hi Andy, You should remove the oil pan and look for leakage around those seals (doughnuts) on your
sleeves. They get like an old shoe that's been left out in the weather. If leakage occurs when tractor is sitting you should be able to locate
the leak with the pan removed. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
