Re: Super C oil pressure
Posted by justin w on January 30, 2005 at 12:43:03 from (216.188.207.180):
In Reply to: Super C oil pressure posted by Glen E. on January 30, 2005 at 12:35:36:
The oil pump bottom plate is aluminum, and does have a tendency to warp. I would suggest checking the plate for warpage. If it is slightly warped, it can be resurfaced, but if the plate has warped alot, you will need to buy a new plate. Also, with the oil pan already removed, it would be a smart idea to check the oil clearance of your rod & main bearings. I also forgot to mention that you should check the pressure relief valve and spring in the oil pump also.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
