Re: Hydraulic Plumbing
Posted by PAULIH300 on January 30, 2005 at 18:20:54 from (152.163.101.13):
In Reply to: Re: Hydraulic Plumbing posted by CNKS on January 30, 2005 at 17:40:29:
The dump cylinder is Dual Acting,the Lift cylinders are Single Acting.They have the inner valve set up for D on the dump bucket and it works...although its theoretically on the wrong valve and the hoses are reversed.The lift HT Valve is set to D although the cylinders are Single Acting.They have the lift hose on the rear port and the hose that crosses over to the reservior (?)in the front.The outer valve is leaking fluid somewhat from the lever seal.I think that "return" hose is partly responsible for that.The engine labors on the downstroke and I dont think thats supposed to.Sounds like its trying to push fluid where it doesnt belong
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
