Re: H not responding to throttle lever
Posted by CNKS on January 31, 2005 at 18:42:13 from (204.249.178.138):
In Reply to: H not responding to throttle lever posted by railroadgoat on January 31, 2005 at 18:34:22:
Have you had the carb off? If so the first thing to check is to make sure the rod and the notched tip that are inside the tube that goes from the carb to the governor are properly attached-- the rod fits in the notch, easy to mess up when you reinstall a carb. In severe cases these parts could be worn or loose. Check the rod and linkage between the throttle lever and the governor. If all is ok, you may have a broken spring in the governor, or perhaps some adjustment is needed.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
