Re: Farmall M rebuilt starter-which type
Posted by captaink on February 01, 2005 at 12:07:39 from (66.115.214.56):
In Reply to: Farmall M rebuilt starter-which type posted by novice on February 01, 2005 at 05:35:43:
Although I have no qualms with ordering from a website, in your case it might be best to take the old starter to a dealer or automotive part house so that you can verify you are getting the correct one.
I don’t believe that the straight M had a 12 volt starter. Te 6-volt will stand up just fine when used with 12 volts. I converted my M over 20 years ago, it is under a loader that I used to use daily in the winter for feeding. I might have replaced the starter once in that time.
Usually when a starter fries it is because of abuse (running too long because of hard starting), low voltage due to corroded connections or too light a battery cables, or the bushings have worn far enough from use to let the armature drag on the fields, not from too much voltage.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
