Re: gas in oil, plugs fouling farmall H
Posted by JOSSETTE on February 01, 2005 at 14:42:20 from (216.114.223.200):
In Reply to: gas in oil, plugs fouling farmall H posted by samray on February 01, 2005 at 13:47:14:
TAKE THE BYPASS TUBE OFF THE TOP OF THE VALVE COVER AND SEE IF A LOT OF AIR IS COMING THROUGH. IF SO, THE RINGS ARE BAD. DO A COMPRESSION TEST AND SEE IF THEY ARE IN SPEC. IF YOU HAVE ENOUGH COMPRESSION, THE ONLY THING ELSE IS THAT THE CARB IS SET TO RICH AND YOU NEED TO TURN IN THE SCREW ON THE BOTTOM-FRONT OF THE BOWL.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
