Re: stuck f 20
Posted by SproutW on February 02, 2005 at 20:12:52 from (209.174.86.35):
In Reply to: stuck f 20 posted by klondike carl on February 02, 2005 at 18:05:59:
I've unstuck a few F-20's in my day and always I've had to take the head off. Pull the spark plugs and make sure a mouse nest is not in a cylinder. Pour your cocktail in each cylinder and pull the valve cover. Check to make sure none of the valves are stuck and soak them as well. It's always a good idea to rehone your cylinders and replace the rings on a stuck engine. It keeps from a costly engine rebuild later. You only need to pull the head and oil oan to hone and replace rings. Good luck.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
