You need to see if battery voltage is getting to the coil. With the points open you should have battery voltage on both small terminals on the coil. Use a volt meter or test lite. If there's no voltage you need to check the ignition switch to see if there's voltage on the terminal that feeds the coil. Check the feed wire to the switch to see if its getting voltage to the switch. If there's no voltage being fed to the switch you need to check that wire to see if its broken or if its a bad connection. Hal
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
