Re: 966...I Gotta split this baby today. Ouch
Posted by Allan in NE on February 05, 2005 at 08:13:32 from (148.63.132.164):
In Reply to: 966...I Gotta split this baby today. Ouch posted by Migraine on February 05, 2005 at 08:00:45:
Hi Migraine,
Ouch! That hurts!
But ya know what? It might not be as bad as you think, although I think you are right about the tractor needing splitting.
You might be right about the wrong gear and the shaft seals....check that PTO shaft bearing while you are there too.
But, I think you are slipping on the high side because of all that oil in there. Main clutch is slipping and will seem to "grab" on the low side because of the increased leaverage of the T/A.
Make any sense?
Allan
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
