966...I Gotta split this baby today. Ouch
Posted by Migraine on February 05, 2005 at 08:00:45 from (24.18.75.6):
After hours of troubleshooting this hydraulic nightmare' looks like she'll still have to come apart. Have completely taken the mcv pump and valves apart and found the good ol boys who put this thing together didn't have a clue about a 966. They put the wrong gasket in between the the inner plate and the valve body blocking half of the ports thus I had no steering and little brakes or TA. We put a new spring kit and a completely cleaned and serviced the valve body. All new oil and new pump at nearly 300 bucks OUCH and still have the awful whine at the pto drive gear. I believe they put the wrong drive gear on the clutch drive shaft since the book calls for a change at serial no 17000. Mine is a 14350 or 72 model and I guess there is a 1 tooth difference and a 3 degree angle difference on the teeth. When I put it together on Tues night I got oil all into the clutch housing and running everywhere so I'm guessing that they failed to put the oil seals on the shaft or have them in backwards. Then there is this new twist which I've never heard of before. When I took it outside for a short test, the steering came right to life, the brakes came to life and the TA worked fine for 3 or 4 times and then hesitated and started working in reverse. When I pull the lever back it shifts into high unless it is slipping on the high side and just feels like it is grabbing more solid on the low side . Anybody have some ideas or help here? I will win the war against this thing but it might have some pains along the way at least in the wallet. Thanks Migraine
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
