Re: 966...I Gotta split this baby today. Ouch
Posted by the tractor vet on February 05, 2005 at 08:26:29 from (4.124.70.96):
In Reply to: 966...I Gotta split this baby today. Ouch posted by Migraine on February 05, 2005 at 08:00:45:
Oh yea i should have told ya that when going back together it is a bunch easier to that the pressure plat and place it on the floor and use your heel and press each clutch finger down and install 1/4 inch nuts between the fingers and pressure plate cover to hold them down then place the cove on the input shaft then the disc on the shaft then slide the tractor back together that way you only have to line up the pilot bearing then go thru the inspection hole and install the cove bolts not to bad to do helps to clean the clutch housing out first that way ya don't have oil and grease running in your armpit. you can get one of them stubby troublelite up in there so you can seeand still have room to work. just bar the engine over thru the starter hole it helps if ya got one extra pair of hands but can be done by yourself. Just remember to remove the 1/4 inch nut when you are done.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
