Re: 966...I Gotta split this baby today. Ouch
Posted by JJK on February 05, 2005 at 09:35:04 from (216.189.131.254):
In Reply to: 966...I Gotta split this baby today. Ouch posted by Migraine on February 05, 2005 at 08:00:45:
About the pto gear, there are 2 different gears, a 26 tooth, and a 28 tooth. Check at your local IH dealer with your model and serial # to see what one you should have. Also check the wear on the teeth of the pto driven gear making sure there is a hump on both sides and not flat on one side(this can cause gear noise). The TA shifting like that is a little strange. Hope the TA isn't fried after having the wrong gasket in the MCV. Just make sure that the TA is adjusted right (spool goes down to the snap ring and pulls all the way up), make sure the dump valve isn't stuck open (I had this happen) but if the lube light works you would have figured that out. You could put a guage on to check the pressure when shifting the TA to see if there could be a major leak (guage should drop just a little for a second and back to full pressure when shifting back and forth). Don't feel bad if you split once for the clutch, put back together, and find you need to split again for the TA. This has happened before and its no fun. Best of luck to you on this one!
Home
| Forums
Today's Featured Article -
Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
